leiniesred
New to the forum. I recently picked up a 1978 Cruisers Inc Gran Bateau with a Ford 351w 240hp with a stringer outdrive attached. I have started to go through everything, and the engine, other than a couple of corroded freeze/core plugs, is in good shape. So I am starting to look over the lower unit. On the lower unit there are 2 hoses running from the top fill plug on the upper unit and the top plug on the outside of the intermediate housing that run up to a "T" connector that then connects to a hose that runs in through the transom that runs up to a plastic oil reservoir that has an OMC label. Is this a system that may have been set up due to bad seals? Has anyone else seen something like this. Sorry I don't have any pictures. I have also noticed that the prop shaft is bent. Thanks
