"Evinrude 150 has a strange pa
"Evinrude 150 has a strange pattern. Engine will start and run normal for approx 25 minutes, then it will start to run very rough and shake badly. Will not throtle up at all, and the idle will change by it's self to 2000 rpm. The engine is not running hot (102 - 104), but if allowed to sit overnight, it will start and run normal again for about 25 minutes. All of the following has been replaced: power pack, stator, voltage reg., optical sensor, water pump, pistons, rings, bearings, carb kit, thermostats (2). What now?"
