capn_morgan
1990 70hp rude on a 24' pontoon. I've already replaced the water pump (complete kit with new thermostat spring and telltale outlet,) and the temp sender. I can cruise all day at low speeds with no issues and have run short distances wide open with no alarm. But trying to run long distances around 4000rpm, it's still alarming. I have two thoughts. First would be that there's a lean spot in the midrange and maybe I should try bigger jets (orifices.) But I'm also wondering if I'm overpropped just a little and it's loading the motor too hard. It's spec is 5-6k wot. With two people on board I get 5400rpm wot. I've got an omc 14x13 prop. I tried a 14x11 but it slipped like crazy and rpm went over 6200rpm and top speed dropped. I usually get the overheat when we have several people and running between 3500-4500rpm. That's what makes me think maybe it's loaded too much with the current prop.
Any thoughts?
Any thoughts?
