1987 - 350Mag Alpha GM V8 (sn B605821) - Always ran great. Sat about a month last year during a rainy summer. went to start and no spark. Pulled coil wire to see if I was getting a spark and eventually it sparked and fired up. Still raining so I pulled boat for the winter. Now, I've replaced the coil and ignition sensor in the distributor. I have 12v on purple/hot side of coil. I pull the coil wire out of the top of the coil, stick a screw driver in the top of the coil and then place the coil wire I just pulled out right next to the screw driver. Turning the engine over I get no spark. The only time I get a spark is if I turn the key to the on possition (not all the way over to actually turn the engine over) then turn it back to OFF, I see a spark jump from the coil wire to the screw driver sticking out of the top of the coil. I can click the key back and forth, and every time I get a spark going to OFF. If there was a kill switch or a funky shift cut off switch, I wouldn't be getting 12v to the coil right? Plus I jumped the shift cut off switch and ohm'd the wires too. The only thing left is the expensive ingintion module but from what I've read here, that's really rare. The local parts guy said he's never sold one. What am I missing?
Any suggestions are greatly appreciated!
