When first started for the day my 96 9.9 hp Evinrude has reduced RPMs and power at full throttle for a few minutes. It will then suddenly rev up to normal speed and power. After a few cycles of this, it will then do fine and respond normally to increased throttle. It starts beautifully and idles fine except it will slightly accelerate while at idle for just a second then idle back. I have rebuilt the carb and changed plugs with no effect. Once it has been running for a while, it operates fine. It has fresh fuel and pumping the bulb has no effect. The power pack was replaced less than 5 hrs run time ago (wouldn't start) Any ideas?
