I'm wondering if maybe this re-built carb I bought online(from a marine carb site) could have came with the wrong jets installed. And if so could that be causing engine to seem to bog or stumble passed mid throttle? All recommended checks of other causes have been done, and seemed fine. Finally tore into this carb ,and found trash and mineral deposits all over the venturi cluster. Soaked and cleaned all parts as recommended here and re-assembled .Didn't think to check the jet and power valve size, but afterwards noticed in this SOLOC manual that sizes of jets varied depending on engine size Mercarb was being used on.Will go back in an check this out.My manual calls for 1.65mm jets and 0.84mm power valve.This dirty carb throws me because fuel system was clean everywhere else. Separator and both filters were clear of trash and water. Problem still there, and all new tune up parts and re-checked timing. Thanks for any insight here.
