Sterndrive wont lift
"No its no the switch already
"No its no the switch already went through that, it will go up if i help it, it is like it doesnt have enough power or something. Is there somewhere i need to add hydrolic fluid or something?"
do u have a 180 outdrive or a
do u have a 180 outdrive or a 280??? I have not heard of a 180??if its a 280 drive is it with power trim or without?? if its power trim i would start by checking hydrolic fluid and if its just power tilt i would check to make sure your battery has enough to lift it.and also that all your connections all well and good...and if thats the case i would look at the schematic that EL P left for ya. good luck sara
