moresparks
Hi, I have a problem on one of my Volvo Penta 290 SP-A Sterndrives and wondered if anyone can suggest remedies.
Twin engine setup and under no wake speed everything is fine. If I increase to planing speed one of the drives seems to lose grip and the revs increase dramatically. The problem also occurs if Increase revs hard in reverse whist docking. At the beginning of the season I could get over the problem by being gentle on the throttles but now with half a seasons fouling the problem is worse.
The problem originated last season but I thought I cured it by replacing the reverse latch springs as one was broken. It still feels like a reverse latch problem and maybe I need to replace all the pawls and catches, but kicking up in forward seems to defy physics!
The trim readings do not alter so the rams or pump is not the issue.
I have had the prop checked for slip.
Gear shift cables all checked and o/k.
As I am on a mooring checking is not easy without a yard lift so need to be well prepared.
So apart from the reverse latch mechanism, could anything else cause this problem?
Thanks in advance.
Thanks in advance.
