Scottybluewater
Boat is a !979 27ft Carver Monterey - Mercruiser 228 S/N 5431395 - 228 Sterndrive - no s/n - pre-alpha - 1978-1982
Situation - changing lower shift cable - the brass bolt/ftg - at the end of cable - the one you need the special nut for
It would not come out - special tool rounded the corners - heat and penetrating oil did not work - nor did Extractors. - or praying
I have grinded the head flush with the housing - intended to drill a pilot hole 33/62 - and then use a 9/16 - 18 tapered tap - fine thread
Problem is i dont know what is on the other side - how far should I drill the pilot hole
Asking anyone if they have had this problem before - appreciate your comments
Thanks - Scotty
Thanks - Scotty
