Stern Drive wonbt go up or down
bigbird
"I have a 1979 OMC 800 stern d
"I have a 1979 OMC 800 stern drive, was working fine then put down now won't go up or down. Solinoids started to click checked and are fine. Next took lift motor and tested on work bench, worked fine. Charged up battery and it still won't move. Please Help."
"this might sound stupid,but i
"this might sound stupid,but i'm new at this.Where would i find the relays.Thank's in advance."
"The 800 series also had a 50
"The 800 series also had a 50 amp fuse on the port side harness at the rear of the head, the smaller fuse 20 amp ran the selonoids and the 50amp fed the trim motor, hope that helps"
i don't think it's ele
i don't think it's electrical i hooked up lift motor without bolting to housing and it will spin when i bolt back up to housing nothing.
"electric motors often perform
"electric motors often perform well under "no load" even when they're pretty much dead. But as far as non electrical problems go, the tilt clutch housing could be all full of water and rust, or the pivot bearings could be tight not letting the drive lift."
"thanks for the info.Got motor
"thanks for the info.Got motor tested and it won't work under load,i need a new motor.Thanks for now."
