"I've read that a growl me
"I've read that a growl means that your gimbal bearing is going. However, before I remove the stern drive to see, I wanted to ask a couple of questions.
The growl is much more pronounced when turning to the right, and barely noticeable when turning left. Is that consistent with a failing gimbal bearing?
I have a bunged up prop; could that be causing the sound?
Further background: last november, when I pulled the outdrive, the u joints and everything were in excellent shape. There was a little puddle inside the bellows, but I wrote it off at the time, because the U joints and drive shaft looked so good.
Also, is it possible for the stern drive to be out of alignment, and maybe that's the cause of the noise?"
