Sterdrive 275a protective helmet start to corode
sebski
"Hi guys,
I notice that on pr
"Hi guys,
I notice that on protective helmet where the front hole is , around that is a bit of corossion. Can I stop it for some how? or should I change protective helmet immediatelly?"
"If the corrosion is not deep
"If the corrosion is not deep and the area is not wasted, cleaning it with a strainless or brass brush and painting it should work. If it looks weak, you are probably better off replacing the helmet. You may want to look for a used one, though. I believe that the new replacement helmets come riveted to the steering fork, and they are not cheap."
