rockstar08
Its bound up, cant move the outdrive by hand and I have broke the steering rack/pinion by forcing it.
Trying to diagnose where its stuck, I have removed the clevis pin that attaches to the end of the steering cable. The clevis pin on the actuator ram is attached. The outdrive is still stuck.
Do I need to remove the hydraulic hoses or something, or is the actuator stuck? Will the outdrive move by hand with only the ram attached?
I tried to remove the steering cable, the nut is on too tight and there's barely enough room to move a crescent wrench a 1/4". Is it better to cut the steering cable and use an impact socket on the nut?
It did this one time before, the outdrive was hit by a lawnmower, we aggressively waggled it left/right until neutral and it worked again. No joy this time though.
-Jon
-Jon
