Steering Question
"I finally got my 84 century 1
"I finally got my 84 century 195 out and running.
the merc 470 purrs like no other, But i noticed the steering seems too easy. After a run across the lake with waves from more than one direction, I found it to be hard keeping on course. At the launch, standing behind the outdrive, I pushed rather lightly and the outdrive swung to the right sending the steering wheel spinning.
Are there adjustments somewhere to tighten this up, or am I looking at a larger problem. The steering systems are not something I have played with as of yet so any info would be much appreciated."
"There are aftermarket drive s
"There are aftermarket drive stabilizers that would help that issue. They are kind of like a hydraulic shock absorber that stiffens and dampens the whole system.
You could try on this site, or do a Google search.
Rod"
"thanks, I'll look into th
"thanks, I'll look into that.
Guy- no it is not power steering. I was afraid I was missing a loose nut somewhere that might send me into the side of another vessel, or in the path of a freighter on the river!!"
Check the steering system inch
Check the steering system inch by inch for what you just said since the steering change came on suddenly.
