bloodintheboat
1980 Merc 110 9.8hp
I changed my impeller about a month ago.
Motors been running fine.
Howeever today, I'm trolling on the lake and the wind picks up so I open throttle up. Pee stream goes from steady stream to a mist then eventually steam. Motor shuts off itself shortly after.
i start it back up on first pull. Peeing a nice stream at idle. Rev up and same thing happens: stream becomes mist next steam then outboard shuts off.
i get home, checked impeller and it was good. Flushed water up water tube. Flushed water down tell tale.
I open up thermostat housing and there is no thermostat?
I go buy one at the store (148 degrees) , put it in. Now took it to the lake.
so with the new thermostat, it eventually does the same thing as before.
Whats going on?
Whats going on?
