Hi all. It's been a while since I last posted, but perhaps someone has good advice for me.
Launched boat back in May. She ran good. no noticeable steam from exhaust. Ran her again a couple weeks ago and saw significant steam. Starboard manifold hotter than port, but not too hot to touch. Engine is at around 180 deg. I plan to shoot everything with calibrated IR temp this week.
I replaced manifold with spare and symptoms are exactly the same. I kept the same swivel riser set-up. I'm thinking of swapping port manifold as I did starboard, but I'm also thinking that I'd only be wasting a gallon of coolant loss and energy working with that 90# piece of iron.
Can the riser set-up leak water to cause steam? My system takes raw water from Hx, into each low side of manifold. Then with out from high point with hose to elbow, up 4 inch extension and into swivel before exhaust hose. There are not a lot of hours on these components. Could the SST collars in risers leak?
Thanks for any input to this. ,Noel.
