Stbd OD wonbt trim up
chiefbill
"The strbd OD on my 2001 Monte
"The strbd OD on my 2001 Monterey 322 (twin 5.7L EFI Mercruisers w/Bravo IIIs) will not trim up. The port OD goes up and down fine. The switch on the handle seems to be working (I hear it click when pushed) The single Trailer toggle switch will run up the port but not the strbd. Pushing the switch in the down mode starts the pump etc and the drive attempts to go down(its all the way down but you hear motor/pump running) but when pushing the switch in the up mode nothing happens. Any ideas out there on how to fix this problem? Thanks. BTW, the trim guages stopped working last year."
"If you can't hear the pum
"If you can't hear the pump running even when you use the trailer button, it sounds like the up solenoid is shot.
With a wiring diagram you can troubleshoot it to see where the power stops.
There is a 20 amp and a 110 amp fuse on the trim pump bracket wiring; check them also; but if it's going down OK I doubt the fuse is the problem.
There is a blu/wht wire running from the up solenoid to the pump; this is the up circuit. If there is no power to this wire post on the solenoid when you toggle the trailer switch, chances are good the solenoid is shot. If you have power, then the pump is likely the culprit.
If it's the solenoid you can run a temporary jumper wire from your battery + post to the blu/wht wire post on the solenoid to raise the drive in an emergency.
Rod"
"Thank you both for responding
"Thank you both for responding. I will chck out the solenoid and see if that is the prob. However, just noticed that I did not specify in my original post that the switch I mentioned pushing for up and down mode was the one located on the throttle handle. Not the Trailer toggle switch. The problem started as intermittent in that I sometimes had to push the handle switch a couple of times before the pump/motor would activate and start the drive up. It stopped working completely in the up mode last week but still activates when pushing the down side. Does this new information change your thoughts on what might be wrong?"
"That changes things,
The pro
The problem is likely your trim limit switch located on the gimbal swivel port side. Likely the switch or the wiring has gone bad, and to replace it requires drive and gimbal removal.
Not for the inexperienced, but it can be done. If you are adamant about getting it working again I would get a quote from your local Merc dealer.
Rod"
"How the trim/tilt works (
"How the trim/tilt works (see last paragraph)
Before you tear anything apart or replace wiring and switches, test it out; first by visual inspection by pulling back and forth on the wires while operating the switches and then test with a meter. At the commander switches, the red wire will always have 12 volts. The green wire gets 12 volts when the trim toggle is held down. The blue wire gets 12 volts only when the toggle is held up or the trailer switch is pushed in. The purple wire is part of the limit switch circuit.
If the switch voltages are as they are supposed to be then go to the trim/tilt pump assy. and make sure the purple wire connector (single wire) and the blue wire connector with two blue wires on one side of the connection are not corroded or loose. These are the trim position and limit switch wires. Pull them apart and inspect; they should be clean and tight; reconnect them.
Next check the three wire connector (RED, BLUE & GREEN) at the pump assy. This plug can vibrate loose and cause your problem. Pull it off and see if the pins are clean and not corroded; reconnect it.
The RED wire in the plug sends 12 volts from the pump assy. to the toggle up/down and trailer up switches. The BLUE & GREEN wires bring 12 volts from the toggle trim/tilt and trailer switches to the two solenoids on the pump assy.
The GREEN wire goes to the DOWN solenoid while the BLUE wire goes to the UP solenoid.
Did you check the switches with an ohmmeter? The trim/tilt switch is a 2-way switch and will show continuity only when it is toggled in each direction between two of the wires.
Up toggle connects the RED wire to the BLUE wire. Down toggle connects the RED wire to the GREEN wire. The TRAILER UP switch also connects the RED wire to the BLUE wire.
The OD trim limit switch will only send voltage to the trim/tilt switch in the upward toggle position if the OD limit switch is below the adjusted trim limit that keeps the OD being out of the water.
To test the limit switch circuit, lower the OD to the down position and slowly raise it with the trim toggle up until it stops. Then measure the distance between the trim cylinder attaching bolts. If the distance is approx. 22 +/- 1/4 inches, then the trim limit switch is adjusted properly and the commander trim toggle switch is working in the up/down mode.
Go to the trim/tilt pump assy. and make sure the purple wire connector (single wire) and the blue wire connector two blue wires on one side of the connection are not corroded or loose. Pull them apart; they should be clean and tight; reconnect them.
Next check the three (RED, BLUE & GREEN) wire connector at the pump assy. The RED wire in the plug sends 12 volts from the pump assy. to the toggle up/down and trailer up switches. This plug can vibrate loose and cause your problem. Pull it off and see if the pins are clean and not corroded; reconnect it.
The BLUE & GREEN wires bring 12 volts from the switches to the two solenoids on the pump assy. The GREEN wire goes to the DOWN solenoid while the BLUE wire goes to the UP solenoid.
Disconnect the trim/tilt assy. wires from the battery and then check each of the nuts and studs on the solenoids for clean and tight fittings. Each solenoid has three wires and the buss bar connected to it. The bases of them have a black ground wire and a small blue wire to one and a small green wire to the other.
On top of each solenoid, the large BLUE wire from the pump motor attaches to a large copper stud with the solenoid that has the small blue wire at the base while the large GREEN wire from the pump motor attaches to a large copper stud with the solenoid that has the small green wire at the base.
The other copper solenoid studs are connected together with a copper buss bar. One of the two studs will also have a funny looking 110 amp fuse attached to the bar. The large RED wire from the battery connects to the 110 amp fuse. This large red wire is the power for this buss bar. A small RED wire attached to the bar stud sends 12 volts to the switches which in turn sends the 12 volts to the solenoids which turns on the pump motor.
Important: if the studs on the either solenoid are dark and not like a clean penny, especially the BLUE wired solenoid, this solenoid is failing due to age and/or a loose bottom copper stud nut. The dark color comes from heat generated inside of the solenoid by the contactor because it is arcing like welding similar to points wearing out. Change the solenoid.
Cleaning Trim Limit Switch & Trim Position Sender
For the trim/tilt problem you are experiencing, if the wires from the limit switch (port side) and trim position sender (starboard side) are in good condition, they (Switch or sender) can be disassembled to clean out the old hardened grease. SCRIBE the sides of each one and the OD for a reference mark before removal. Clean out the old grease and pump fresh Mercruiser 2-4-C grease thru the zerk fittings before reinstallation. Clean the small brass contact points with solvent and a pencil eraser until shiny; repack w/ 2-4-C grease and reinstall by aligning reference marks."
"I am having the same problem
"I am having the same problem the gage does not mark any thing and I have to play back and fowerd with the shicth at the trotle handle untill it goes down but nothing on the gage, hopefly I dond have to take the drive down again on my bravo 3 I just replaced the belows two weeks ago do you think that I have the same problem ?"
Hector:
Read the post above
Hector:
Read the post above yours. It provides a step-by-step trouble shooting procedure.
"Have been having a problem wi
"Have been having a problem with the trim/tilt on my Bravo III drives and while I was checking out the wiring at the pump/motor I checked the fluid and found it to be a uniform milky white. Does anyone know how water can get into this system and how the problem can be corrected? Additionally, I think I have determined the switch in the shift/throttle handle is bad and that this is why I can't raise the Strbd drive. Anyone know where I can get new switches or a new handle containing the switches( Quicksilver Command 3000)??? Thanks"
"Welcome w. gregory:
It&#39
It's best you start a new post for more responses.
Water in the trim oil can come from a loose or leaking hose connection or failing lift cylinder. Your switch problem may just be a broken solder joint in the handle wire assy.,. Read the following.
Switch available from Sterndrives.Com Inc
