I purchased a 1998 Carver 405 with 454/350hp Crusaders inAugust 2012. During initial sea trialSTBD engine was smoking heavily (think old locomotive steam engine). Surveyor had his mechanic look at engine andfound spark plug, second cylinder, portbank, was running @ 125 degrees while other plug readings were 165degrees. He replaced the plug and wiringharness for all plugs. Second sea trialshowed problem corrected and I bought the boat.
Back home andafter 15hrs of mainly bubbling (1500 to 1800rpm) I was checking the engines and noted that the
coolant reservoirfor the STBD engine was empty. Irefilled, to the full line, and put another 5 hours on her. I
checked againprior to the 1.5 hr. trip to marina for haul out/winterization. Coolantlevel was 1.5 inches below
the fillline. On the way to haul out I put theboat on step, 3400rpm, after approx. 2 minutes I noticed heavy
smoke coming fromthe STBD exhaust. I throttled back to1800rpm for the 45 minutes balance of the trip, no
smoke.
Both engines,after reaching their operating temperature of 170 degrees at the helm gauges,never get cooler or
hotter throughthe rpm range regardless of how long the cruise period might be or at what rpmthey are running.
At operatingtemperature elbows are both warm to the hand, not hot,. STBD engine manifolds and elbows were
replaced in2009. Engine runs great and oil is clear; I mean clear. It is so clear that it is hard to see on dip stick.
Yes, it is thereand at the full mark! Engines are closedcooled with 380hrs on them
That’s it fornow. I’m thinking head gasket or headitself. Prefer neither and am hoping forsuggestions or ideas.
Thanks much,
jimmyd
smoke.
Thanks much,
jimmyd
