1982 Johnson 140hp
Motor: J140TLCN, 1982 Johnson 140hp
I have another post (1982 Johnson 140hp Spark Problem) describing my problems up to this point. I decided to start another thread.
I have replaced the stator, am now getting good strong spark on all 4 cylinders and thought I had this thing licked. We went for a test on the water this past weekend and the motor will not run properly.
It's a bit difficult to get started. When I do get started I have to idle it up fairly high (about 2000-3000 rpms) to get it to keep running. Then when I try to put it in gear it dies almost immediately.
I'm thinking that the timing is out of adjustment because of the stator being changed. Am I off base here or is there something else to be considered?
I'm vigorously searching the forum and my service manual for suggestions and proper method to ensure timing is correct but thought I would also ask for help.
Thanks in advance,
Trey Monson
Thanks in advance,
Trey Monson
