M
mike tolley
Guest
the ohm meter readings on my
the ohm meter readings on my stator are 302ohms. the manual calls for 270 +/- 50 ohms. well within spec.the manual also says that the charge coils supply the powerpack with 300 volts ac. i connected my volt meter across the 2 leads going to starboard pack and cranked the engine. i read 74volts ac. is this the right way to test? if not what is? where could i find a neon tester at? im starting to point at the stator.
