Stator Part Number Needed
nemer
I have a 1979 175hp V6 Mariner. My serial number doesn't work at marine engine.com. I want to replace my stator because I have done everthing else to try to get my engine to run good instead of OK. I would like to fine a NOS stator and save some money. Can anybody give me a good part number to look for, and or point me to a good deal on the stator I need
Yes, I was going to suggest the CDI part as well. Comes in about 60 bucks cheaper than OEM and I have had good luck with them. In some cases I prefer the CDI parts to OEM - find the wiring superior (thinking of some of the tiny gauge trigger wires that Merc produced)..
That should have the 9 amp stator.
Merc's OEM number would be 398-5454A7 - list's upwards of $260 (10% less at some on-line Merc part sources)
CDI part CDI174-5456 is the most economical (this site sells it for under 170 bucks) or
Sierra part 18-5871 which goes for about $200.
So you have options. Personally, I would go with the CDI stator. Their "stuff" is decent quality...
Here is the Mercury Stator 398-5454A7 on PartsPak.com.
http://www.partspak.com/productcart...ator-Assembly-V150-175-200-225-3776p19973.htm
Here is the sierra stator 18-5857 (it is showing as the replacement for 398-5454A7. I don't believe the sierra number given in a past post was not the correct number)
http://www.partspak.com/productcart/pc/Sierra-18-5857-398-5454A7-Stator-V150-225-3783p4097.htm
Here is the CDI stator 174-5456
http://www.partspak.com/productcart...5454A-9-398-5454A17-398-5454A18-3377p7902.htm
The CDI stator is the cheapest. I like their stuff the best also, so this is a win-win. They also have good tech support. Good luck with your repair.
