Stator Meltdown
takem4fun
"I have a 1990 Evinrude 200hp
"I have a 1990 Evinrude 200hp E200CXESM. It appears the stator has melted. There is a black shiney substance that has melted away from it on the the block ( but it's not sticky ). Do I need to be concerned about rectifier, timer base, or power pack damage? Or can I just replace the stator? Thanks"
"u can just replace stator,if
"u can just replace stator,if u have no running prob's.and,get that extra batt out of the system."
"Motor purred like a kitten ti
"Motor purred like a kitten till it died on the water. I only have one battery, Just picked up the boat so not sure what the previous owner had. Also can you tell me if that motor is a low compression ot not? 80 psi on five one at 77. Thanks for the help."
"that is too low---,however,if
"that is too low---,however,if all r reasonably close on compression,run er till she blows,or,do a complete,overhaul..."
"I thought that was low as wel
"I thought that was low as well. Your opinion, is it more cost effective to rebuild now? Just worried about throwing a rod or somthing catistrophic, not so concerned about piston and rings."
"v-6's very rarely throw a
"v-6's very rarely throw a rod....if it is running good,...let er rip....just be aware,that it needs attn..
if your finances,will allow u to rebuild now...do it...however,......do it...PROPERLY...do not do a short--overhaul..they will always,come back to bite u in the ass.....in the very near future.....always...do it right,do it once,and u will be good to go,for another 10 yrs."
"Thanks for all the help and i
"Thanks for all the help and info, I'm a new member and sure do appreciate the prompt responses. Tim Hogan"
