" I have a Mariner V6 200 hp 1
" I have a Mariner V6 200 hp 1986. The motor runs "great" out of the water. When I get my boat in the water it only runs to 1700 rpm. First i think it was a fuel problem so I rebuild the carb and looking at reeds when I was at that side on the engine. Next step was the electrical and compression. Compression relative good on all six 120 psi. Then I checked electrical. Triggers ok , Coil ok , spark on all plugs, have hard to se if it weak or strong. When i check the stator gainst the manual I found that I have some different ohm value.
Wire Manual My
Blue-Red 5400-6200 3540 bad
Blue/White-Red/White 5400-6200 5970
Red/White 125-175 66 bad
Red-Ground 125-175 142
Beacuse stator is very expensive in sweden, I want to be sure that´s the problem. "
Wire Manual My
