glorious_one
Avid reader but rarely ask. Any ideas most are most appreciated. I have a 332 amerosport with original 1987 454 crusaders. Keep tuned every year and have had only routine probs until now. I keep the fuel tanks segregated, i.e.,port engine running off of port tank and the starboard on its tank even though i have a crossover valve. On my annual trip to south jersey from phila via del river and bay, my port engine lost power after running approximately 5 miles. Changed out fuel/water seperators, canister filter on block, and small filter on rochester carb. No improvement. Changed out original mechanical fuel pump and installed new fuel line back to water/filters bypassing canister filter. Boat ran about 10 miles @ 3200 rips and then died but would restart but not go over 1200 rpms.in gear. Assumed it was a fuel pick-up in port tank issue so before doing that, i shut off the port tank and using crossover valve, ran both engines off of the starboard tank that has not been a problem. Boat now runs @ 3200 for about 50 minutes and i think i have isolated that the prob must be in port tank and/or pick up tube. Regaining my confidence, I decide to run up the rpms to see if four barrels get enough fuel as well. Boat revs up to 3800 but then dies after about 30 seconds. Limp home (again) on one stbd engine, problem port side will restart but no planning power. Now i am not sure if my original conclusion of a prob fuel pick-up is the issue. Any help getting to my beloved Wildwood, New Jersey pre-paid slip is much appreciated!
