Thanks for the comments! To answer the above questions I did use new gas and fuel cell. I did not use any starter fluid. All I did to get it to start momentarily was pump the tank ball, choke it and it started up. Since my post I did remove the carb and thoroughly cleaned it reinstalled and it started right up and continued to run. I then did lake test and it preformed pretty well. After about 45 minutes at various throttle positions it started running rough and lost power so I had to limp back to dock. I think at minimum I need a carb kit and then go from there! Thank You for you comments!
