I acquired a 1960 Marlin Runabout with the original Gale Buccaneer 35 HP Electric motor (I Believe it is model 35DE13B) which is basically a 35 HP Johnson rebranded. There were only 6 of these boats cast then the factory burned down so I would like to keep it as original as possible. The motor has both a pull start and an electric start but the pull start was not working at all (not engaging). I am a bit ok with two stroke engines but not that good so I got an expert to take a look at it. He said he could fix it and took it apart last fall then disappeared (Expert = X- as in an unknown quantity and Spurt - as in a drip under pressure!!!) leaving me the parts. I have it back together and verified the electrical/electronics. The engine turns over well and I think I should at least start it up with the specified 24:1 fuel mixture to get the oil flowing and penetrating (I don't think the motor has run in the last 20 years at least). I have the Parts and Service Manual but not a User's Manual and I do not know the exact starting procedure. Also there are two knobs on the front of the motor that turn out and I do not know the proper settings for them. Just wondering if anyone has a User Manual or at least knows the settings and starting procedure... I am just grateful that I was able to get it all back together and turning over after the "expert" was finished with it...
