Starting problem clicking noise battery terminals hot
silverfox
"I have a 90 hp outboard mercu
"I have a 90 hp outboard mercury 1988. Won't turn over, hear clicking noise and after two minutes battery terminals very hot. Any ideas will be appreciated."
"Just some ideas....Could be a
"Just some ideas....Could be a bad battery, bad connection at the battery or engine, bad starting solenoid, bad starter motor or engine is seized. Check, clean all connections, charge battery, try jumpering across the 2 big terminals on the solenoid, try to wrap a rope around the flywheel and pull it to see if engine seized or put a big wrench on it(Note: turn key OFF) remove spark plugs to make it easier to pull."
"Thanks Bob. I got new battery
"Thanks Bob. I got new battery, changed the battery wires. Engine not seized. Same problem. Brought it to my mechanic. Will advise."
"same thing happened to mine,
"same thing happened to mine, it was a bad starter"
