Starting NS15
stdewar
"After starting within 1 or 2
"After starting within 1 or 2 pulls all summer, I am now having trouble starting my 2 stroke Nissan 15hp. I have cleaned the plugs and filter screen. Still won't start. Other ideas?"
start with ignition and compre
start with ignition and compression if thats good then id start in the carb may be a block passage or something you have good gas in a clean tank
"Usually its a dirty carbureto
"Usually its a dirty carburetor due to fuel evaporation. Have the carburetor cleaned. To prevent the need for future cleaning or to increase the service interval, start disconnecting the fuel line from the engine after every use and let the engine run itself out of gas."
"Thanks, Is cleaning the carb
"Thanks, Is cleaning the carb something I can do or do I need to remove it and take it in for servicing?"
yeah i agree with mr t guru if
yeah i agree with mr t guru if you dont think you can then dont there not that hard but i have been doing all my life
