Hello all. Hopefully you can help. I have a 2003 2 stroke Johnson 115 HP. Was out fishing and just wound't restart. The starter would spine but not fast enough to make the Pinion Shaft Assembly lift up and turn the Flywheel Assembly. I have replaced the starter and determined the Pinion Shaft Assembly isn't the issue by using a friends new one with the same part. When turning it over the starter does not turn fast enough to make the Pinion Shaft Assembly lift. I have manually put the Pinion Shaft Assembly up to the Flywheel Assembly and it does not have enough power to turn. Please help. I really thought this could be a DYI.
