Rjg30091982
Hi guys
had an issue in a previous thread which I've now sorted after 10 hours with a multimeter!!!
next issue is an issue the boats had since I've had it! It starts up pretty well and runs perfectly, each cylinder has 100psi exactly however sometimes cold sometimes warm it won't start and just turns over and over and doesn't even cough or splutter.
i used to squeeze the fuel bulb 3 times but now do it till I can't squeeze any more 30 odd times but this still doesn't change much, I've cleaned the carbs and again nothing.
today I changed the plugs and it fired up! However the old plugs were about 2 months old and about 6 running hours old, they were golden brown and not oily which I think is good.
is it fuel? Is it electrical? As I said it's not that it struggles to start it's more has no spark at all then after 2-3 minutes will cough for about 5 seconds or so then run. But it runs perfectly then!!??? Doesn't miss or cough at all. All fuel hoses are also new and new jubilee clamps all tight!
thanks in advance!
russ
thanks in advance!
russ
