starter woes
The release of the bendix drive is caused by the engine starting. The flywheel then is spinning faster than the electric starter cranking speed and the bendix gear is forced out of the flywheel teeth.
If the engine doesn't start, the bendix gear will stay up in the flywheel teeth.
That was it. Hung up doing your timing procedure, but performed properly when starting this AM.
