I was doing the Joe Reeves Maximum Spark Advance technique on my 1993 Johnson 25hp, and before I could double check the completed timing adjustment, the starter stopped working. It looked like it was the solenoid, so I did the test on it. Here is the page for the Solenoid test from the manual for my 1993 Johnson 25hp:
I did the tests and got infinity, 0.L for test #1, and for test #2 the solenoid clicked and the reading was infinity 0.L. I got the same for two other old solenoids that came with a spare 115hp engine I bought 2 years.
I bench tested for continuity on the two small studs and got continuity. I tested for continuity on the two large studs, the battery and starter lugs, with the two small lugs hooked up to battery, and the ohmmeter hooked up to the large lugs, and the solenoid clicked and I got continuity at the large lugs. Again, all three solenoids gave the same results.
With the ignition switch key off, I took the battery cable end that normally hooks up to the solenoid, and touched it to the short cable that goes to the starter and the starter turned over.
It looks like the starter is OK, however, are all three solenoids bad? On test #2, if I'm reading the manual correctly (it says: "If the ohmmeter reading is a high reading, replace the solenoid"), the result of 0.L, infinity, on all three says that the solenoids are all no good and must be replaced?
Any advice would be welcomed.
