wharfcreek
"Well, here I am again!! Seem
"Well, here I am again!! Seems I'm not yet done with this project. Having just completed the process of resolving the engine overheating problem by having my heat exchanger rebuilt, and replacing that raw water pump, I'm now back to a No-Start situation...this time resulting from a bad starter solenoid. I say this as I've had it apart, and it appears that the inside of the solenoid housing may be failing....what appears to be a 'liner' of some kind inside the solenoid magnet structure seems to be the cause of the problem. When pulling the solenoid core from the winding housing, I see what looks like a stainless steel sleeve or liner inside the housing. There is a lateral seam or open split in that sleeve, and instead of being flush in a linear pattern keeping the cylinder bore straight and true, this liner or what ever it is appears to have one side folding over the other at one edge, thus rendering the starter solenoid bore to become somewhat conical. This is worsened by the fact that it's at the outer end, not the inner end, so that sleeve is grabbing the core and essentially 'binding' it up. Bottom line is, that unless I can find a new solenoid, I'm going to have to replace the starter. (the starter motor and drive seem fine). So, my question is: Any suggestions on repairing this unit, will an automotive unit work, or are you aware of any potential 'fix' for just the solenoid portion itself? If not, any suggestions on where to buy perhaps a used or reconditions one? I did check ebay and didn't find anything I thought looked similar to my unit. Again, the motor is a 230B, and it's in an 1995 Excel 18 foot open bow runabout. By the way, the engine seems to run wonderfully well now, and I'm delighted about that....but the funny thing is this whole affair began with a 'no-start' symptom from what appeared as the starter....and now, after new timing belts, new distributors, new relays, new throttle safety switches, and even a new battery....I'm back to the starter itself again...only this time I think I can plainly see the cause. Any help would be greatly appreciated. Thanks all, from Tom Dickinson. [email protected]"
