Starter Problem 2014 Yamaha Outboard
What 2014 Yamaha?
Charge the battery. If you think it is charged, load test it.
If passes load test, I’d be looking for bad cable connections or corrosion inside the battery wires
Will it start if you put a jump pack on the battery side of the solenoid and a good ground?
What 2014 Yamaha?
Will try when I get back to pontoon . Thank you for excellent and prompt advice .
