Mike,
Went through the same drill with my 88 Blackfin 29 7.4L. Some basic troubleshooting will identify the problem. Your engine is equipped with a slave solenoid behind the heat exchanger and a starter solenoid on top of the starter. The neutral safe switch is located on the right side of the trans and is normally wired in ahead of the slave solenoid – although sometimes between the slave solenoid and starter solenoid. Let’s assume your NSS is ahead of the slave solenoid. Recommend starting with the starter and working forward. With the ignition switch off, (on the starter solenoid) jumper the small post with the red/yellow wire to the large post with the red wire. This is usually accomplished with a screw driver. The starter should immediately engage and crank the engine. If so, the starter and starter solenoid are OK and the problem is some where from the slave solenoid forward. Next concentrate on the slave solenoid. Confirm the “click” you hear when turning the ignition switch to start is actually the slave solenoid. If so, the NSS is OK and the problem is between the starter solenoid and slave solenoid. In my experience, foreign-made slave solenoids have a high failure rate. You will notice two red/yellow wires going to the solenoid on separate posts. One wire is 12VDC in from the ignition switch (by way of the NSS) and the other is12VDC out to the starter solenoid. A common problem is the solenoid clicks but does not send voltage to the starter solenoid. Using a voltmeter or test light, confirm that both red/yellow wires are carrying 12 volts with the ignition switch turned to start. If the solenoid clicks but no voltage is present at the other red/yellow wire post, the slave solenoid is bad. If both red/yellow wires are carrying voltage, confirm the voltage is making it to the red/yellow poston the starter solenoid. If not, the wire between the slave solenoid and starter solenoid is shorted or broken. If your slave solenoid does not click with 12VDC at the red/yellow (voltage in) wire post either the solenoid is not grounded (Crusader uses a dedicated ground wire at the solenoid) or the solenoid is bad. Checking the NSS is straight forward. The NSS has two screw connections which provide continuity to the startred/yellow wire circuit. With the trans in neutral and the ignition switch turned to start, voltage should be present at both screws. If not, the switch is bad. After replacing at least one slave solenoid each season I installed two Arco solenoids which were exact Crusader replacements and have not had any problems since. Please keep us up todate on your progress. Good Luck,
FL Panhandle
