Starter Motor Earth Connection
mr_johnson
"Where does the Starter Motor
"Where does the Starter Motor earth connect to?(circled) .
It is the Johnson 1989 110Hp outboard.
"any solid ground will do try
"any solid ground will do try the engine block,
clean it up good before you sock it down"
"there is no ground----on the
"there is no ground----on the starter---that is the hot wire,when solenoid is engaged...it grounds,thru block conn."
