"Just purchased a boat w. a 19
"Just purchased a boat w. a 1983 Merc 90 hp 6 cyl 3 carb. It is very hard to start,in fact could not start it last time after sitting for week in very damp weather, but seemed ok previously once it was running. I notice when cranking the engine that the starter often 'drops out' a second or 2 after turning the key, ie the starter motor gear will engage the flywheel momentarily then drop out. Would this indicate a bad starter solenoid(which seems to be built into the starter motor?)
or a weak battery? The engine will turn over normally once in a while. Also, any hints on best starting sequence? I have tried part throttle, full throttle, no throttle, and choke only. Usually results in flooded engine(lots of gas coming out the carb throats, particularly the bottom carb). This is my first large outboard, haven't worked on them before, so any advice is welcome! Thanks"
