BoatAlaska
My starboard Crusader 270 with less than 300 hours since rebuild will not go past 2000 rpm. Found the distributor (Prestolite) mechanical advance was locked up. Pulled, cleaned and replaced all equipment (points etc.). Same issue after repairing distributor. Swapped Carbs, swapped coils, timing and dwell set. Still the same problem. Pulled and replaced both fuel filters. Starts and idles very nicely.
How would you tell if the exhaust is partially plugged?
What's next?
What's next?
