Hello!
I have a standard rotation 360 circa 1989,leaking oil. in a twin installation 1989 rampage.
opposite rotation runs great and doesn't leak a drop.
standard rotation is leaking from the Pan/oil filter/rear seal area, due to its location i cant find the exact location
I was thinking to do a dye test to attempt a pin point leak location.
This leak is definitely a "live with" amount but its a PITA to keep bilge clean, lost 1/2 quart in the last 20 hours of running.
Was thinking of yanking the enigine at the end of the season and attempting a fix. I've been reading all over that the rear seal is problematic and difficult to keep oil tight.
Ideas? live with it? do pan gasket and rear seal? once its out should I decide that route, anything I should do while its out? Valve job?
Greg-
Greg-
