skipper_who
"I have a 73 evinrude 3 cy. Th
"I have a 73 evinrude 3 cy. This engine stalls every time I put it in gear.I have try all the ideas that I read in other post no luck ,
I cleaned carbs 3 times compression cy 1 115 cyl 2 105 cy3 115.Cyl.2 was redone by previous owner. I have to use choke to start have throttle half up.Slow it down to a little faster then idle.
When I put my hand over Num 1 cyl carb no different the other 2 slow engin down.If I move the throttle manuly it crank up fast no hasatation. Im at whitts end any help You may have I will try it thanks Still can,t put it in to gear. Skipper who."
