"Here is the problem i'm h
"Here is the problem i'm having and hopefully someone has an answer for me. The motor is a 93 evinrude 225. When I launch the boat it will idle and go into gear no problem (runs perfect). However, when I shut it off, let it sit, even for as little as a few minutes and re-start, it will idle, but when I shift into gear the motor will starve for fuel and stall out. The motor re-fires fine but will keep starving out a few times unit it seems to get enough fuel to run fine. The choke has helped prevent the motor from stalling a few times. The motor has been just rebuilt and the problem was there befor the rebuild. When it was re-built the carbs were all rebuilt, new vro pump, and the check valve on the gas tank is working fine and clean. Anyone know what I should be looking at next?"
