I clean the carb,first1979 318s in a f32 trojan....port engine stalls at low idle when throtle is applied....Also dosent seem to rev as freely as starboard...I just ran her 175 miles in 2 days with the port engine if anything being a little more thirsty than starboard.....Any ideas....
The Monkey nailed it: Poor accelerator pump reaction in the carb, and a sticking advance mechanism.
On the carb, be sure the linkage rod that operates the accelerator pump is in the hole CLOSEST to the carb body--that will give a maximum squirt.
On the distributor, pull the rotor off, put a few drops of oil on the felt pad below it. Then replace the rotor and 'flip' it back and forth a minimum of a HUNDRED times to free it up. (Put a song on the CD player and flip 'til it's over.)
If that doesn't do it, start looking at plugs and wires.
Jeff
Dialing in more idle richness will help, but the problem will remain: Your acclerator pump shot is not enough to overcome the lean condition upon throttling up.
What type of "new carb" did you install, another Carter AFB?
Jeff
Jeff
..." I had 4 to 6 volts. "
I've seen that as well on mine but they run fine.
I hate to say this, but your Edelbrock may have the same issue as one of mine had (and another as reported here): The low speed passages inside the carb were partially plugged by the lead that the factory uses to seal up the drilled passages. I had to drill out all of the lead plugs, thread the holes, and epoxy screws into the holes to cure the acceleration problem I was having (which was identical to yours).
I talked to the tech rep at Edelbrock about this (and their practice of not providing a vacuum port), but they denied any responsibility! Maybe you could do better? I'll gladly back you up on it if you want me to.
Jeff
Could also be electrical. I had identical problem on my port motor.
It was low voltage to the ignition ecu and coil.
My failing house battery was draining the port motor battery.
I had them paralleled and the alternator regulator was shot.
You should have about 9 volts at the coil when idling. I had 4 to 6 volts.
