About a year ago I received much advice and positive help here on the conversion of my 2006 V8 GXI-F to closed circuit cooling, (as apposed to raw water cooling) Much discussion was about whether to include the exhaust manifold/risers in the cooling circuit.
On this subject someone suggested replacing the heavy cast iron manifolds and fitting SS extractor exhausts, then the problem would go away.
Well I did this late last year and the results are very real and obvious!!
They weigh approx 1/4 of the cast iron units. So much so that the top of the stern drive is now about 1.5" above the water line.
Because the internal curved "extractor" design allows for much greater and freer exhaust flow I recon I have gained about 30-35HP (I am not exaggerating) The suppliers do state a gain of 30HP on a 270HP engine.
The acceleration is also much quicker.
Also I estimate that the fuel usage at a moderate speed of 40-50Km has decreased by about 15%
They are of a one-piece design with no separate riser bolt-ons so the problem of corrosion and hydraulic locks goes away.
They are designed as a single one-piece fitting from the engine manifold ports to the flexible transom pipes, so they need to be specifically frabricated for each engine/stern drive configuration.
However there is one caveat: Because they are individually fabricated to fit the engine model and type (of which there are many). The mounting brackets for the ECU, ignition control unit, oil filter and other components that are normally mounted on brackets which bolt to the OEM exhausts, now need to be accurately positioned and welded to the new SS exhausts.
This is where problems can occur.
In my case I had to make additional extensions and adapters from 3mm mild steel plate so as to match the located positions of the components as they were fitted to the cast iron risers on my 2006 GXI engine.
Now this is not a high price to pay IMO for the vast advantage that the SS exhausts offer and for other engines there may be no problems at all.
I cannot understand why the big three do not fit them as standard, unless there are problems that I do not know about.
