Inspected gas lines at two barbs... It looks good on inside. The line is A1 USCG MARINE 3/8. I don't think the line is the problem. I have anti syphon inline on top of tank under non removable deck. I can access it from the fishing box next to tank but very tight. I figured I would just test it. When I removed the line from barb at first filter, the racor 20 micron paper water separator, I found gas in line and when I sucked on it (not too hard) I got gas. I think we are good but wanted to know what pressure vacuum it should flow. I will measure with a tool later to be sure it's spec.
so I thinking next could be Oring issue on top of racor letting air in.... When I opened it I didn't think I had enough gas in it. I removed old Oring, cleaned racor lid and groove, installed new Oring. I filled the racor with gas and closed her up making sure to tighten it up well. I filled the carb bowl and started boat... Ran well for a while then ran out of gas.
I ran out of time and closed up for night. I think either I still have air leak or fuel pump. This is starboard engine so pump is tough to get to.
Thinking I could take the racor out of the picture by connecting the lines together to bypass. Also I could set my line after racor in a plastic tank bypassing anti syphon and racor.
I have steel lines from second filter, to the fuel pump and from the fuel pump to the carb.
I have a pressure/vacuum tester I used for cooling system and I think it can be used in fuel lines too. That should measure the pump I think.
is there a better way to debug this issue?
