M
Mike Babel
Guest
"Hi all. Hoping someone here
"Hi all. Hoping someone here can help me out. I have an '89 Rampage with twin chrys 360lm's. I believe they are 265hp. They are original to the boat with 900hrs full fwc system, electronic ignition. Rochester quadrajet 4bbl carbs. Anyway, instead of having the yard do the work I'd like to tackle it myself this year. Please let me know if I'm missing anything on my "to do" list:
1. replace racor fuel filters
2. replace pencil zincs in the heat exchangers - if I lose coolant doing this do I simply top off with straight anti-freeze or the pre-mixed stuff?
3. replace the fuel filters on the carbs
4. change oil (5 qts of 10w40 castrol plus a pint of STP oil treatment)
5. change oil filters (fram ph8a)
6. replace spark plugs (need help here - anyone know the proper gap - I believe champion plugs are in there now) also should I use "never sieze" or just some 3 in 1 oil on the threads?? Plus what's the appropriate gap for the plugs for these engines??
7. Had new water pumps and impellors done last year along with boiling out the heat exchangers so I should be good on the cooling side.
Am I missing anything??
Mike"
Mike"
