Splitting the leg
fat_boy
I took the bolts from around t
I took the bolts from around the lower gear case and the bolts around and under the trim plate.But the leg still does not come apart from the upper gear case.The leg is off a 1988 0mc cobra with a 3.0 eng.Did i miss anything?
"Try heating at seam with a to
"Try heating at seam with a torch all the way around. Usually it sticks after awhile.Tap with rubber mallot when heated, should seperate."
