Dngermouse78
Hi all. My first post here, I've been able to find most answers by searching the archive however could not find a good answer on this issue.
Outboard in question is a 1976 55hp evinrude, model 55643e.
I purchased the motor a few months back from someone who did not know anything about it. The boat it was on had tags from 1997 so I assume that's the last time it ran. I replaced fuel pump, ignition coils, spark plugs, water pump impeller and rebuilt carbs. Adjusted carbs and timing per Joe Reeves instructions I located on this board. Runs great but carbs spit a little fuel out the front at idle and mid revs. Is this normal? Seems to be really bad on fuel economy as well.
Also, after setting the timing without engine running per Reeves instructions, it seems my timing did not advance the 4 degrees while running WOT on the water with an assistants help. I set it at 15 degrees with throttle at WOT and spark plugs out, rigged to a spark tester. On the water at full speed, timing is still 15 degrees. My engine calls for 19 degrees.
Thanks in advance for any and all replies.
