Speedtwin year and HP 1968 25 hp
Martin Haisman
I have a speeditwin which the only serial number is 309065. I am guessing it is a 1965 28HP, however I can not find info on actual year and HP. I live in New Zealand so obviously it is exported here.:confused:
Re: Speedtwin year and HP
my book does not show a 28hp for 1965. the last year was 1964. maybe Joe can help you out.
Thanks. Joe if you are out there any clues? I have looked all over the motor and can't find any other serial numbers. Could be a 1964 looking at some youtube vids but the cover on the NZ version may be misleading.
Can you tell from the piston size as I have the head off at the moment.
Cheers
Marty
Appears to be a 62 model--------------Bore is 2.875" --------Stroke is 2.750"-----------------------35.7 cubic inches.-----weight standad length--a mere 120 lbs.
Many thanks - does the book say HP? According to my deteriorating grey matter there is no way to directly convert CI or CC to HP
Cheers
62 to 64 were advertized as 28 HP-------------------later it was rated / sold as a 33 HP from 1965 to 1970.
Based on the parts diagrams on this site, there appears to be a slight difference in the hoods from 62 to 63 to 64. The 62 model is showing an emblem on the rear (part # 35) not listed on the 63 motor. The 64 cover doesn't have the applique just behind the Evinrude on the side and has the Evinrude further aft, smaller and inside the v shape applique. Look for a welsh plug on the block with numbers 28202 (62 short shaft), 28203 (62 long shaft), 28302 (63 short), 28303 (63 long), 28402 (64 short) or 28403 ( 64 long).
