I installed floscans last year and have a nagging issue. BTW, I went with the 0-32 twinscan unit on my carb'd 454's.
My issue is the port side needle randomly floats all over the place so I've never gotten an accurate reading. Sometimes it'll settle down and I think it's close to the port side consumption. The Stb side is fine. I called Floscan and they sent me another sensor but that didn't make any difference.
I think the general consensus is a tiny air leak somewhere between the tank and the sensor. Obviously no fuel leaks. I have copper line from the tank to the crossover valve and then everything past that point upstream to the engine is new. I plan on replacing the copper with flex line but wasn't going to until the fall when I come out. In the meantime, is there anything I could use to try and seal all of the joints from the outside in the meantime? I was thinking of trying rescue-tape?
I've checked and tightened everything. This would be a lot easier if it was a fuel leak, air is hard to detect
The only other variable is the way the Racors are mounted. Flo-scan calls for the sensor to be mounted so that it's always full of fuel and pumping slightly "uphill". Instead of using another 45 degree fitting to accomplish that, I have the Racors mounted with a slight tip to one side. This setup has worked fine on the Stb fine since I did the install but thought it was worth mentioning.
Thanks!
Bob
Thanks!
Bob
