Spark problem Maybe
oldfart
"I have a 1983 9.9 Eninrude E1
"I have a 1983 9.9 Eninrude E10RCTR with a spark problem on #1 cyl. New plugs, new spark wires, and I have spark on the wire and plug if it is pulled out and running only on # 2 cyl. I can feel moisture from gas in the cyl as it is running and see the spark.. Can it be out of timing, or a power pack problem? Where should I start?"
"Engine NOT running. Spark plu
"Engine NOT running. Spark plugs removed. Crank engine and check the spark which should jump a 7/16" gap with a strong blue lightning like flame on both cylinders.... a real SNAP! Does it?
Plugs should be Champion QL77JC4 plugs, gapped at .040 or the alternative gap of .030 .
Check compression. What are the psi readings?
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
"Thanks , Joe. Compression is
"Thanks , Joe. Compression is 90 on both cyl.
Plugs are ql77jc4 at .030, good spark at both spark plug wires when pulled with no plugs in."
"With proper spark (junps
"With proper spark (junps a 7/16" gap?) and compression, you're back with the fuel system. Check for a leaking fuel pump diaphragm, then double check the carburetor for cleanliness and adjustment.
An out of adjustment slow speed needle valve (if it exists on that model) will cause it to drop one cylinder.
(Fuel Pump Diaphragm Test)
(Two Hose Type Only)
(J. Reeves)
Note: This pertains only to the regular Two Hose type fuel pumps.
Leave the hoses attached to the fuel pump. Remove only the two screws that attach the fuel pump to the powerhead. Re-insert those two screws and install a nut to each of them so that the fuel pump is securely clamped together. With the fuel line attached to the engine, pump the primer bulb while observing the pressure/vacuum operating hole on the back side of the fuel pump. Should any fuel leak out that hole, the diaphragm is faulty.
If the diaphragm is faulty, the fuel pump will require rebuilding or replacing. Note that repair kits are not available for all fuel pumps, in which case replacing the pump would be necessary.
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
